Is it easy to fit the V6 Cup front towing eye onto a standard V6 Exige ?
Depends how deep you are in the gravel trap Pete
Just spotted this thread and wondered if anyone has a sensible answer.
Fitting the front one is quite simple just bolts to the bottom of the towing post using the same points as the post,
Does require a slot cutting in the front grill for it to pass through though, easy enough but once cut you can’t put it back!
Rear one is another matter I’ve not fitted mine yet
