all the US cars have a oil leak coming from the crankcase breather where it bolts to the block. you will see oil on the filter and also on the pan. do the UK cars also have this problem ? whats the fix? thanks carl
Noticed that on my S last time i had the diffuser off. Dealer said TADTS…
It’s just oil being dumped out of the gearbox breather, and yes if you load the car up hard in corners it’s just a case of TADTS.
Plans Motorsport do a catch tank if it’s a problem!
it’s not gearbox oil it’s motor oil and it comes from above the oil filter. whats the fix??carl
Carl - do you have a photo showing the problem?
