Uprating fuel pump
Heya
Does anyone know of a good pump that’ll fit in the place of the stock lotus fuel pump? Assume a Bosch 044 is too big?
Thinking of swapping to a proalloy tank, and wanted to get a new pump that will support 300+
T
Speak to Greg at Hangar111.
see they have a drop in 255L, seems to be for 'yota cars though, will it work in a rover based elise?
I can certainly suggest a good pump for 300+
The Fookin beer pump at wetherspoons cos it,ll dull your pain when the box explodes !
thankfully mines gotta honduh lump n box
thinking a proalloy central collector tank n 044 stashed somewhere would be ideal, especially if I can get one like gregs but single pump
really want to avoid complicated fuel setups n lot of hoses.
^^ bastaad ^^
:slight_smile:
044 deffo the way to go. Just make sure you get a genuine one.
In tank?
You can get in tank 044’s, but they aren’t the best as you have to mount them a fair distance from the bottom of the tank. Best to use the standard pump as a lift pump to a swirl pot and then the 044 as a pressure pump.
What about the tank that pro alloy does with the central collector?
Like gregs but with just one pump.
