high 220s low 230s on Emerald rr now. Add the dry sump that I have done that similarly the Caterhams enjoy, and I would expect another 10/12bhp. Even just the scrapers that all but
You have posted recently about the terrible windage and 80% aeration caused by the awful Caterham dry sump system, how exactly does that tally with the 10-12BHP increase that you suppose it gives? According to your postings it is worse than with the wet sump so accordingly must be costing the engine power, we’d better add some to my figures then to take them up to the wet sump equivalent, 10-12BHP would seem fair. Then we can add another 10-12BHP for a decent dry sump system, then we can add 5-10% with a set of dual injectors… See how ridiculous it all sounds?
Perahps we should add ‘Splitfire plugs’ - 5BHP, ‘Nology leads’- 8BHP, ‘Broquet’ fuel catalyser - 10BHP, Ebay special ‘air temp sensor resistor’ - 10BHP etc.etc… pretty soon we’ll all be up to 1000BHP.
Get real Simon, you are living in a fantasy world, the RR Uldis uses is considered generous compared to Dave Walkers rather than the other way round. We’ve already played that one out.
The fact is that despite your claims Uldis’s engine is a country mile away from ‘Butts’ engine in terms of power torque and spread of torque, similarly it’s a country mile away from the last few 1800s of mine that have been to Emerald and are of almost identical spec. That is depsite countless trips to the RR and a large number of exhaust manifolds who’s pipework would probably span the globe if laid end to end.
Get over it.
I hope that your engines do produce good power, and I don’t have the slightest interest in a BHP war, you started the debate by falsely claiming that Uldis’s engine was close to Steve Butts, it isnt. Right now the published figures just dont support your case.
I’m sure that further development of the engines I have mentioned in various areas would take then even further away from the current crop of your engines, it just comes down to the cost/performance benefit for the owners.
In all the cases the engines have been to the RR once, no plethora of manifolds, induction systems etc. with multiple RR runs, just one run, out of the box.
Dave
