Need a set of fronts (currently running R888’s all around).
Has the Toyo R1R’s come out yet for S2 Exige wheels?
regarding R888’s - which place is currently cheapest?
I think the R1R’s are slightly different size’s to the R888’s but will still fit the exige wheels (think they are wider).
I think if they wear better I’ll go that way next time.
Boothy
As your your other question at a guess Camskill as they nearly always are
just checked, the only R1R size is 205 on the front - is this too wide?
It seems most people using the R1R’s on Exiges are using 205 front and 235 rear. I will also try them shortly.
Ex77
Worth trying tyretraders.com for 888’s. Picked up a pair of rears a couple of weeks ago a lot cheaper than camskill even with the SELOC 20% off.
