Tyre pressures
What pressures do people run for day to day communting etc ?
22 at the front, 24 at the rear.
Also monitor your pressures regularly (assuming you have AO48’s?).
The reason I say that is that my pressures have been all over the place following the cold and now warmer weather. I think the AO48’s really suffer, or are sensitive to, changes in temperature.
As Chris says the temps can be all over the place on A048’s
I’ve got the tyresure pressure monitoring and most will say it’s a gimmick but I find it really useful and a great safeguard should something go wrong.
In the recent cold weather I run mine between 22 and 24 cold and look for a 2psi increase. I’ve found 25-26 hot all round on the road gives a good balance
