tyre pressures
I’m doing my first track day at Donnington in June. Can anybody advise as to the best tyre pressures for the day. My car is fitted R888’s.
General opinion is anything from 23-28psi when hot. Try them and see what suits you best.
Check them more than once. Sometimes takes a few sessions for them to stabilize, especially if you are building up pace through the day.
And put some more air in before you go home otherwise they will be around 18psi.
‘Typically’ for me 20 & 22, tried 20 all around at Croft and it seemed to work as well !
As Will says, pump 'em up before you set off home.
Thanks guys, I’ll have a play around.
