Confused on what tyre pressure should be in my S2 tyres. The manual has 2.0bar back and front…surely this can not be right. Shouldn’t the front have less? When I went to check they had 1.6bar in both front tyres 2.0bar in the back.
Use the search function loads of good info on this
My hand book states 1.8 Bar F & 2.0 Bar R, which for road use feels ok.
Tim.
Will be high look at the contact patch and wear rates. I found the middle of my first set wearing at a higher rate = over inflated tyres
My first set of rears were set at 28psi which was way to high. Am now running 24/25 and working/wearing much better.
If they wear out in the middle they are definitely overinflated, no matter what the book recommends.
Don’t know why but Lotus always recommends higher than optimum pressures.
The S2 is heavier, but on my S1, ROAD pressures are about 20-22 psi.
Fat barsteward!
Only kidding, will buy you a Tequilla thingy on Saturday
Plenty!
Tim.
Thats what I have in mine Tim and it seems OK.
Thanks for the replies guys.
Not being funny…is there an easy way to see this?
Nope. Tread depth on a part used set will be your only friend
…or drive through some tacky floor paint at the desired speed & tyre temp, then come back for a look
Tim.
Won’t be looking for a garage with glass ramps then
