TRD V K&N Apollo?
I am trying to cut down the amount of noise as the trackday police are getting forever harder to beat :frowning:
So I have a cunning plan and as EA have tried lots of air boxes/filter on the S and only found the TRD and Apollo to be any good, so has anyone had both? Is the Apollo louder or quieter?
I plan on running the intake tube off the roof scoop, I’m not sure if it will help for drive by noise or not but it has to be worth a try.
Apollo will be louder mate, I had one on my old 111s and they are much louder than a standard type airbox.
The oem airbox has a snorkle to kill off sound, is it possible to retrofit one to the TRD? or would that just restrict airflow and make the TRD pointless?
Just replacing my Apollo with a TRD this week.
Can post up the diffrence at the weekend.
As I understand it the Apollo is slightly better than the TRD but the TRD has a better MAF sensor possition and allows you to retain more of the learning parts of the ECU when you remap.
Will report back soon.
Ex77
I have also heard of a snorkel for the TRD but it was on Seloc so you can never be too sure, anyone else?
Might be interested in your Apollo though :wink:
whats the verdict then Apollo or TRD ? who is the loudest
Noticed these apollos on ebay �130 posted !
Having had the TRD for a week it is deffo quieter than the Apollo. Not a huge amount but there is a difference.
Makes my Exhaust sound better !!
Ex77
Has anyone ran the TRD box with the K&N panel filter ( part number 1997-2003 LEXUS K&N AIR FILTER #33-2145-1) or the Blitz panel filter (part number 59504)? . Both these can be obtained cheaper than the Lotus sport paper filter for the TRD from the lotus dealer
that’s my setting, K&N with TRD
Is it quieter or louder than the paper trd panel filter ?
no idea, as i went directly with the K&N airfilter when i installed the TRD airbox
I have a 2nd hand appolo coming, then I will be doing a bit of fabrication work to get it to use the air from the roof scoop, I am hoping this will help with drive by noise readings, I’ll let you know :wink:
Just fitted mine today and went straight for the K and N element
what a nightmare job ! ended up redrilling the two mounts (bit of guess work) holes nearest the wheel arch to get it to fit, by know means a straight replacement for the standard box
Sounds great ! fair bit louder than the stock airbox and I cant help thinking it picks up better at low revs , prob just my imagination !however the car sounds right now as opposed to a 1.0 litre hatch back
Not a bad mod for �62 including the K and N of ebay which was cheaper than the lotus sport paper element.
De-cat next hmmm …?
