TRD Airbox - VSV Bypass
Just finished fitting my TRD Airbox and whilst I was at it thought I would show people what I have done with the VSV valve as theres pleanty of pictures of the box installation floating about but nothing on bypassing the valve.
I removed the VSV from the top of the airbox, removed all the vaccum lines connected to the vaccum chamber and from the airbox. I also disconnected the vaccum lines to the throttle body and actuator and removed it from the car.
Instead of just blanking off a pipe, or re-fitting the VSV I decided to leave it all off the car, I simply tied up the electrical connector plug with a tie wrap (leaving disconnected hasn’t thrown up a MIL light) and then used one single piece of vaccum line to join the throttle body to the actuator as pictured below.
Here are some pictures to help;
[image]http://www.cmpracing.co.uk/uploads/exige_vsv1.jpg[/image]
First picture shows all the vaccum lines removed from the car, I have labeled it up to show where they went.
[image]http://www.cmpracing.co.uk/uploads/exige_vsv2.jpg[/image]
Second picture shows the one piece vaccum line between the actuator and TB
[image]http://www.cmpracing.co.uk/uploads/exige_vsv3.jpg[/image]
Close up of the new vaccum line, I actually used a piece from the old VSV pipe work so no parts are required to do this bypass.
I hope this might be of some use to those fitting the TRD Airbox at a later date, I found removing the intercooler pipe work gave much more room to work and easier access.
Was your TRD air box distorted in any way before you fitted it to the car?
What you mean distorted? If you’re having problems lining up the three holes thats normal.
