How often should you need to top up the water in the charge cooler header tank?
Although I do check levels regulary, I’ve just had to put 1.5 litres of water in - second time its had to be topped up in tha last 6 months. I always thought with it being a sealed system it would never require topping up?!
It is a sealed system, so if you are topping it up at all you have a leak. If you can’t see the leak then the charger core in leaking on the inside and this is very bad as you could end up hydraulicing your engine. Get it checked out ASAP!!!
Have a good look at the seams on the charge cooler, look for discolouration or cracks in the welds, also take it off and look round the back and underneath, there should be no need to drain it to do that. As Sean says if there is nothing obvious get it checked with a pressure tester or similar.
Cheers Guys. I’ll have a look but not sure how obvious it will be as it can’t be a bad leak if it doesn’t need topping up often.
Not having much look with leaks - I have to top the coolant up too every other week as the jubilee clip of the front rad is leaking ever so slightly. Need to get both leaks sorted asap with winter coming!
Is yours an early pro alloy kit? I only ask as there have been a few reports on Lotustalk of their earlier kits failing (welds cracking) although I think they resolved this over time.
They suggested sending the unit down to them for it to be tested, but I don’t have the old intercooler to replace in the interim and I need the car at least 1-2 times a week.
So they have suggest taking it off and filling it with water to see if there is any obvious signs. Will give it ago this weekend.
Adrian - I may take you up on that kind offer, depends really on what Proalloy can do for me first. Will be ringing them Monday after I’ve taken it apart.
No problem just let me know and I’ll drop it in the post to you.
Cheers for the help guys. Still not had the charge cooler off yet, it probably won’t have time until next weekend now.
However, the water pump has now stopped working (not sure if this is related?!) Will give everything a good inspection at the weekend, but can anyone conform where the pump is located with the proalloy charge cooler system?
My original one is on the outlet pipe from the bottom of the header tank, but yours was fitted by the owner wasn’t it? So it could be anywhere? I suspect it is unlikely to be the bosch pump as they are generally very reliable, if you do need a new one they are a bosch PAD12V try ebay
