To Accusump or not Accusump that is the question
A witty title to draw out the feedback from the exige community.
I run a VHPD K series with verniers, polished inlet and exhaust tracts, emerald and custom mapping on both road and track.
What are your thoughts?
Is or has anyone put an Accusump on a K series 1800cc engine and what feedback can give me?
Thanks alot guys in advance.
I was thinking about it, and found out that it’s not a must have item on a K series. Buffled sum, then goes dry sump.
A good windage tray and a good baffled sump will see you right. Especially if you are just using 888’s / 048’s
Baffled will be fine Jez. I run one on mine and turn some pretty quick laps now. Even unbaffled… the K-series actually has pretty fantastic oiling (so long as it’s mounted transversely, not longitudinally)
