I have noted the last few outings that the car wants to (and has) stall.
Most notable:
Very hot day last year, car in sun all day. Started and left running while I talked to someone. Stalled twice when pulling away and needed more revs to pull away.
Long motorway run, came off at a junction and slowing to stop, the revs dropped quickly and I had to blip the throttle to hold it from stalling.
Last week I went to Supercar Fest. When driving the car seems fine but when in a traffic queue it occasionally wants to stall, revs dropping low and I have to hold it with some revs.
Other times it seems fine, drops to a tick over as normal but quite a few times I need to hold it from dipping too low with revs.
Have also noted it occasionally seems to want more revs to pull away from a stand still.
I changed the battery before Supercar Fest hoping this would cure the problem, it hasn’t.
Next week as part of it’s service I will change the plugs (4yrs old).
I have some throttle body/carb cleaner. I’m thinking of cleaning the TB this weekend - saturate a clean cloth and wipe it round.
Will be checking the intake for air leaks.
Anything else you guys could suggest?
