Team Dynamic Wheels or photoshotop guru
Has anyone got an exige with these wheels fitted?
alternatively a photoshop guru
http://www.teamdynamicsracing.com/pro-race/Pro-race12.htm
not sure about the weights but they are much cheaper than exige wheels
anyone know what the standard wheels weigh without tyres?
I hope this helps a little…:slight_smile:
cool thanks
According to that fitment chart mate, they don’t do our sizes.
There’s definitely a thread on wheel weights if you have a search, I did weigh a couple myself to contribute to the thread but don’t seem to have kept a copy of the info! I also think that there was a degree of variance in the weights from several different people…
the offsets are a little different but not a problem as its only 15mm and the exige rear arches will fit them in with ease, wheel width you could go for the 8j or 9j not bad for less than �500 a set though
I did do a search but couldn’t find it either, the 9j wheels are just over 10kg’s and the 8j is 9.5 kg’s which sounds quite heavy the fronts are just over 8kg’s
still not sure whether they suit the exige though
the 9j rears are the same as they use on the wtcc/btcc so they must be strong
quote]anyone know what the standard wheels weigh without tyres? [/quote]
thread here
Thanks Steve
"@8.5kg = front rimstock without any tyre (but about 100grams of wheel weights & a rubber valve!)
@11kg = rear rimstock without any tyre (but about 20grams of wheel weights & a rubber valve!)
both were weighed with a Salter spring balance rather than the bathroom scales! "
so they are lighter than the rimstocks
so they are lighter than the rimstocks [/quote]
I think you will struggle to find any rims heavier than the originals…
I am not so sure on the look of them; i think it’s the lack of that nice deep dished rear that really gives the agressive focused look you get with the original slabs of iron !!!
The Jury is out on this one currently…
The team dynamics wheels refered to in my text are the same as mentioned at the start of this thread BUT 17/18 inch. The kuhmo tyres aswell…all the other stuff is S2 (sorry) Exige 16/17 inch…
there may be something of interest for you guys…
Wheel 111 R Series Front 5,5x16 6,9 kg
Wheel 111 R Series Rear 7,5x17 9,5 kg
Wheel Exige Series Front 6,5x16 8,8 kg (Euro cast exige wheel)
Wheel Exige Serie Rear 7,5x17 9,4 kg (Euro cast exige wheel)
Wheel DSC Race Front 7x17 7,9 kg (Inexpensive cast wheel)
Wheel DSC Race Rear 9x18 10,4 kg (Inexpensive cast wheel)
Dunlop Formular R 205/50/16 10,2 kg Compound SPS
Dunlop Direzza 02G 225/45/17 10,8 kg Compound H1
Yokohama A 048 195/50/16 8,3 kg Compound MH
Yokohama A 048 225/45/17 9,7 kg Compound MH
Kumho Ecsta V70A 205/40/17 8,4 kg Compound K 60
Kumho Ecsta V70A 245/35/18 10,9 kg Compound K 60
Complete Wheel 111 R inkl. Seriestyre Front 14,8 kg
Complete Wheel 111 R inkl. Seriestyre Rear 19,1 kg
Complete Wheel Exige Front with Yokohama 17,1 kg
Complete Wheel Exige Rear with Yokohama 19,1 kg
Complete Wheel Exige Front with Dunlop 19,0 kg
Complete Wheel Exige Rear with Dunlop 20,2 kg
Complete Wheel DSC Front with Kuhmo 16,3 kg
Complete Wheel Exige Rear with Kuhmo 21,3 kg
Its all part of my on going 17/18 inch wheel evaluation program…
Hi Dave, I ordered a set of these a couple of weeks ago- should have them in the next week or 2 so I will post some pics when they are on…
w
Hey Wayne, how is your car coming along?
w
to be fitted to an S1 or and S2? or more importantly what are the PCD and offsets?
w
That is the question, do they fit the S1?
w
Yes that is the question! we will have to wait and see…
Heres the info from TD…
LOTUS EXIGE SERIES 1
Pro Race 1.2 (Black)
4 x 3.75 PCD
FRONT = 7 x 16 ET 15 (2off)
REAR = 9 x 17 ET 23 (2off)
I may have to mess around with spacers on the rear…
Should have them soon so I will keep you posted.
Hi Russ…
Yes very well thanks…
The body is now painted and we are putting it back together…
I am messing around making a splitter and undertray at the moment… always takes longer thay you expect.
Ps One of the lads is welding your chargecooler as we speak so hopefuly we will be able to send tomorrow/monday all being well…
Did you take the water tank with you or do I have it here somewhere??!!??
Great stuff Wayne, ta.
When you say water tank, is it the square one which attaches to the bulkhead? If so, you have it. I only took the front rad/cooler assembly.
Russ
ok Russ- I have it here…
could you call me with your adddress details etc?
