I’ve got light problems!! - sidelights, fogs and rears not coming on, main & dipped beam are working fine.
I’ve checked the earths, fuses and light switches - all ok.
Is this likely to be the switch pack module behind the stack gauges needing replacement?
any help appreciated.
Best wishes
Dave
Easy job.
The SPM lives under the dash binnacle. A couple of screws either side of the binnacle allows the removal of the hood. The SPM lives behind this, just unplug, remove a couple of fixing screws and jobs a carrot.
I have a few pictures when I did this and there is ia good write up on Elisetalk. I will post the link later.
thanks Peapod, can you remember how much this costs? I will be fitting it myself.
I’ve had a look for write up, but couldn’t find it so would appreciate the link if you can send it, cheers
Dave
[quote=stratosboy]thanks Peapod, can you remember how much this costs? I will be fitting it myself.
Dave [/quote]
About �71 + vat from Lotus…
Cheers Dave
Hi Peapod,
Any chance you could send the link from Elisetalk about doing this job, and your pics too if possible?
Thanks
Dave
Will do, the information is on my PC at home so I will add it this evening.
The link below is regarding the US daytime running lights, but it still tells you how to remove the SPM.
Thanks Peapod
All done, all fixed - new switch pack module fitted, thanks everyone, especially Peapod.
Dave
Well done.
