Trying to find the best tyres for hillclimb use … in UK
Very soft, upto temperature quick and dont need to last very long
Seems not so eay to find anyting in the right sizes for 16 and 17 … in OZ we can get A050 in soft compound and those seem to be raved about … but not available in UK ??
I do National Hillclimbs in the UK , the best tyre is Toyo R888 , which is eligible for the Road Going classes, supply during 2011 was restricted after the well known problems in Japan / floods etc …
Alan Meaker is the man to talk to at Toyo Tyres in the UK
The yoko wets give a very consistent feel straight off the line. I’ve used them for rallying. However there’s too much tread block movement and they’re no match for a soft slick in damp or dry conditions.
I’ve tried Dunlop rally slicks in X22 supersoft compound and Kumhos in K10 compound and they’re great with surprisingly light wear rates on an Elise. As already said, it depends if you are allowed to run them in the regs.
Exige will have to run in sports Libre class, so I think tyres are pretty free … will check that though
Problem is the 16 inch fronts, there are not a lot, if any options … Avon dont do the correct size/compund combination unles syou buy 50 ( info from BMTR ).
Ive also looked at Kumho so thanks Wes will look into those more and the Dunlops
