Just a quick one.
After not driving my S2 n/a Exige for about a month i noticed that on occasion after releasing the brakes they lightly stuck on for a second or so, even after 20 or so miles, this happened during low, moderate and hard applications. The car is only used as a 2nd car, but i have never experienced this before ?
Any ideas or advice gratefully received, Rob.
get it in the elan, its either the servo or master cylinder sticking. lots of use sorts it
Ha ha, i knew someone would use the " drive it more line " i wish i could be driving it more and making the most of all the good weather, but have been to busy with work.
I will see if the problem is still present next time i drive it and if so will check the servo or master cylinder.
Thanks for your help, Rob.
Lol … don’t look too hard for the cure , probably minor surface rust / sticky sliding parts …probably self cure itself …
Servo ? Maybe clean the filter if it reassures you … master cylinder ? Nah !
Regular driving is the key
