Is there any need for these if I’m going to run 110/120 ride heights ?
No, you shouldn’t need these as that’s just standard ride height for an exige.
Are you lowering or raising the car?
Ahh…cool, thanks matey.
Was thinking it would be a bit lower sat at 110/120 (currently getting some Nitrons fitted).
Would 100/110 be better ?
Dave, 110/120mm (112/122mm if someone wants to get really picky)is the standard ride height. Going lower usually helps the handling but you can go too low (100/110mm isn’t too low btw)especially on soft springs and the sound of scraping glass fibre is pretty 'orrible!
The better damping and stiffer spring rates from the Nitrons even on a road based set up will make a big enough improvement to both ride and handling without even changing from standard ride height.
The best I can advise with ride heights is:- If you’re unsure what to do,start standard and gradually get lower, and if the car isn’t corner weighted when the dampers are first fitted you’re not really messing anything up if you have a go at adjusting it yourself.
HTH
Azreal
Are you & Mr Kipling making an appearance at Oulton on Saturday? Sure do hope so - give me a ring when you’re 10 mins away from the gate
Sure am Mr P, wouldn’t miss it. Thanks very much .
ps Are you running the VVR ‘how many CV joints’ sweepstake this weekend?
