Anyone know the specs for the std cams in the Toyota engine?
Will
Will
In case anyone else is interested this is what I’ve found
Low cam:
Inlet duration: 228 degrees
Inlet lift: 7.25 mm
Exhaust duration: 228 degrees
Exhaust lift: 7.25 mm
High cam:
Inlet duration: 292 degrees
Inlet lift: 11.4 mm
Exhaust duration: 276 degrees
Exhaust lift: 10 mm
