I was just getting ready to come to Donny on Saturday to see you all but my car decided it didn�t want to come with me!
A week or so back the battery completely run flat so I charged it up and its holding its charge ok. The alarms disarming ok, ignitions working fine, fuel pump primes etc, immobiliser appears to turn off ok too but the engine won�t turn over. It seems like there�s no power whatsoever getting through to the starter motor.
I�ve just found these threads HERE and HERE pointing in the direction of the alarm / immobiliser but just wondered if anybody ever found a common cause before I literally try to push it around to Horizon
You need to check if you get 12v on the solenoid when you try to turn it over - if you dont then its quite possible its the imobilisor or the crank relay - you can check the relay for 12v from immobilisor or you can short out the imobolisor and “hot wire” it quite easy
If your around weekend give me a shout if you need help
