A couple of weeks ago, I started the car up and it made a nasty grinding noise while the starter was running. I thought maybe the solenoid hadn’t engaged the starter motor fully?
It’s been fine since then, until this morning: The first time I tried to start the car, instead of hearing the starter turning smoothly, it seemed to be pulsing at regular intervals, maybe 2 or 3 times per second. They were very short pulses, almost very loud clicks.
I’m slightly suspicious of my starter button because I had it disconnected a couple of days ago to remove the air vents. The connection doesn’t seem very tight. I wouldn’t expect such regular pulsing if it was a bad connection, though.
Forgot to say, the car started completely normally on my second attempt this morning. When I got to work, I restarted it 3 times to see what would happen. All completely normal
Sounds like a dodgy connection to me, either battery, solenoid, starter or that fancy button you have? Maybe even the ignition, if that was touched during fitting for the button What about the main earth lead?
I checked the connection on the starter button last night. Seemed hunky-dory, but I tried bending the pins on the plug slightly and then wrapped insulation tape around the plug to make sure it doesn’t work it’s way loose.
I’m coming around to the idea that it may just have been the battery because the car hadn’t been used for a week.
