I undestand there’s a common problem with the engine stalling, and that the fix is a new ECU map, and adjusting the throttle for a higher idle speed.
Is that right? Any more to add to that?
I had a problem with the engine nearly stalling. Usually when I’m going into reverse. After any use of the throttle, the revs would drop to around 400rpm, almost stalling, and then it would catch itself, and return to a good steady idle @700rpm ish.
I got Nick Whale’s to check it out, and if anything the problem got slightly worse. Now it would actually stall sometimes.
I had them adjust the throttle again, now it idles at about 900rpm, but sometimes it still comes very close to stalling at about 400rpm.
It is a common problem & AFAIK the ECU needs a re-flash as you’ve thought.
Mine was done following the engine re-build ( ) due a broken valve spring. Symptoms were actually similar. Yours will hopefully be just the re-flash though.
Suprising NW’s didn’t just sort the fix there & then.
Brendan
I had the same prob Sept 04 S2, LRV (Lotus tech was onsite that day) remapped the ECU and adjusted the throttle body’s. But I’m pretty sure it didn’t result in a higher idle speed. Not that it matters I suppose but it did the trick.
John
Mine has never stalled…(Touch wood ). It feels and sounds lumpy when first started up like it might stall but never has. When it gets warmed up it is fine from then on.
Well, after all my previous comments on the lack of personal experience of this problem, it only went & stalled this morning
I was reverse parking in town on a not quite up to operating temp engine, which I suspect has nothing to do with it. Brendan, was your problem reversing into the garage with a cold or hot engine?
This may sound daft, but old MR2 mk1s did a similar thing when hot, sometimes when you let the revs fall too quickly they just carried on all the way to zero!
The ECU didn’t just depend on a vacuum for idle advance I think it used electrical load too, as you could switch on the lights or even the interior fan and the revs would rise.
