Stack lighting
My instrument lighting has stopped working-anyone any ideas please?
Put another 50p in the meter? :smiley:
Check first (if you haven’t already…) that you’ve not caught the switch. If it’s not that, then the backlight is supplied from fuse 16, which also supplies the RH sidelights, so check this hasn’t blown.
The backlight uses LEDs, so it would be unusual for these to all fail at once. If it’s neither of the above, then possible a bad connection/broken wire so no power to the lot.
Thanks!But I’m not sure where the meter is.
Just ignore Pete, hes probably been on the pop again!!!
Is it the one under the stairs :open_mouth:
