Took helmet out of it’s sheep skin lined bag to find the gel coat has blistered all over (Bell mag 6)
Any Ideas?
Should I replace it?
Is it safe?
Sent a message to Bell via their web site but no reply as yet
I’d thought I might paint it but worried that if I go to that trouble more mole hills might appear over time.
Recon I might have a go at the ultimate DIY carbon wrap.
Always like a challenge???
Be like wrapping up a football as a Christmas pressie!
Bit of elbow grease and some old paint I found in the garage
Pic does not do colour justice it is actually Fluro yellow.
Should look ok when buffed up.
Well… it was either repaint or buy a new one.
If I look like a dick in it recon I might have to buy a new lid
Won’t be a Bell tho!!
Bell mag 6 is fibre glass.
I think it is acrylic skid lids you need to be careful with, even stickers can be harmful on some if I recall.
Paint I used was left over when I painted my towing eye
The blisters are where moisture has been trapped under the outer lacquer. This can be a result of the original manufacture, where the lacquer has been applied too soon, or can be moisture due to the way the helmet has been stored, eg. if it has been cold/damp.
I’d suggest keeping it in the house rather than in the garage and preferably in a thin helmet bag rather than anything thicker; in itself a lined bag is likely to retain any moisture more readily than a thin one.
Also, always allow plenty of time for it to dry out after using it before storing it; it might also be worth putting in a couple of silica gel desiccant bags when it’s being stored (there are often small ones in the packaging of electronic items, eg. cameras, etc. that are fine for the purpose).
These chemically absorb water and are incredibly effective as they can hold their own weight in water - so even a small one weighing 10g or so will hold 10ml of water (which is quite a lot - try spilling 10ml to see!).
Hope that helps and remember - always look after yer helmet!!
