This weekend my car has been running at 92c - 100c in traffic is this normal ? weather was nice though
Sounds hot to me! Watch that gasket.My standard Exige (178bhp not 190) never runs over 90 degrees.Ian [image]http://www.exiges.com/ubb/NonCGI/images/icons/blush.gif[/image]
What can i check or do to help to lower the temp? quote:Originally posted by IDG:Sounds hot to me! Watch that gasket.My standard Exige (178bhp not 190) never runs over 90 degrees.Ian [image]http://www.exiges.com/ubb/NonCGI/images/icons/blush.gif[/image]
Keith, Here’s my list of possible causes to overheating. Suggest you eliminate the easier options first.1)Insufficient coolant in the system.2)Thermostat faulty3)Radiator core blockage/grill restricted.4)Radiator electric fans/sensor faulty.5)Engine management system faulty.6)Pressure cap faulty.7)Auxilliary drive belt worn/slipping.8)Ignition Timing incorrect.9)Inaccurate coolant temperature sensor/sender unit.10)Air-lock in the cooling system.hope this helps, good luck with locating and fixing the problem.
