Spinning roof retaining bolt
Hi all.
I have just finished fitting my seats and was putting the roof back on.
Last bolt then wham! It just spins. It wont undo, or redo.
I am guessing the captive nut has come lose?
Now, how do I fix?
Part 22 in this diagram is just spinning
I had this, and it was part 16 not being seated properly at the front…
I have the roof off now , but I can only assume the captive bolt has come loose?
Congratulations, you now own an Elise. :frowning:
I think you’re going to have to go digging for that rivnut, replace and reglass :confused:
It feels like it’s attached to the bolt , I can’t get the bolt out!
Bloody thing. Teasing me.
I have zero GRP experience, This might get contracted out .
sure I took the roof back off, then started with that corner - maybe the issue I had was different
I appreciate your guidance fella.
I have whipped the roof off , but the bolt isn’t going in or out. I am pretty sure the captive nut is not captive any longer
Andy its not too difficult to do, if you research fibreglass bobbin replacement/repair then this will help you.
If you can still get a copy Miles Wilkins from fibreglass services did a great book.
Lee - that is useful. Thank you. Ill take a look for the book and how my roof is made up of.
You might have saved me buying a full mohawk carbon roof that I had convinced myself I needed …
If you factor in time, I’m sure you can convince yourself a carbon roof is cheaper, somehow
http://elantrikbits.com/lotus-elan-blog/bobbins-remove-and-replace-job/
For reference later after work …
I have a similar challenge with my tailgate, I can’t adjust the height of my “stoppers” because of spinning captive nuts but luckily my tailgate lines up properly so it’s a back burner stuff for now.
Carbon tailgate sounds good
Carbon tailgate and roof panel sounds even better …
:thumbup:
I think I am going to attempt the repair.
I am working the following principle
  1. I attempt a repair and it works but if that doesnt work
  2. I can goto a bodyshop if they cant fix it
  3. I can do the usual thing and fix it by throwing cash at it and go carbon roof . See point 4 after purchase
  4. Ill request a bodyshop paints the carbon roof in a semi transparent silver coat like the Ferrari F40 for maximum show off effect
