M11
9 February 2013 15:20
1
To set up the profile for my Torque plugin on Android it is asking for my speed at 2000rpm in each gear? I can look on the speedo but I’d like to get it more accurate than that.
So any clever buggers on here who can work it out based on gear ratios etc?
S2, 6 speed Toyota engine. Started life as an NA
Any help would be much appreciated
jfk
9 February 2013 15:28
2
Use the gps speed off torque itself if all else fails ?
I think Ade once had a graph of ratios tho …
ade
10 February 2013 10:35
3
I’ll have a look to see if I still have the spreadsheet
Try this spreadsheet from Gearboxman
I used it to select a FD drive ratio to go with my Kaaz gearset
M11
11 February 2013 11:25
5
In case anyones interested this was given to me on SELOC:
Mph @2000 RPM Mph @4000 RPM
11 21
16 32
22 44
28 56
39 77
40 81
Mph @6000 RPM Mph @8000 RPM
32 42
48 64
66 89
84 113
116 155
121 161
ade
11 February 2013 11:40
6
somewhere in that the maths doesn’t work on the multiples and gaps between gears but it should be close enough for most purposes.
SeanB
11 February 2013 22:01
8
Yeah happy birthday matey.
jfk
11 February 2013 23:27
9
Happy birthday Mark …
Is your age in the first table or the second ??
M11
12 February 2013 10:11
10
Cheers for the Happy Birthdays guys
[quote=jfk]Happy birthday Mark …
Is your age in the first table or the second ?? [/quote]
5th Gear at 2000rpm
SeanB
12 February 2013 10:29
11
Its better than bouncing off the limiter in 6th like Pesky!!!
