I’m going to get the SPA dual oil pressure and temp guage, and see from previous posts that there may be a problem with the wiring harness being too short to stretch to the dash. If I’m asking them to make up a special harness how long should I go for?
The plan is to mount it in one of the air vents, not on a pod infront of the gear lever.
Dont know since your goiing to mount them in on of the air vent… but infront of the gear lever u need 3.6 m… so you could just measure from the gear lever to the vent.
From memory 6m should be fine, but I’ll check what I asked for at home tonight. It does depend a little on where you’re mounting them, I have mine mounted in front of the gearstick.
Each SPA gauge has a single button for setting/resetting it’s myriad of functions. I wanted them accessible but out of the way. Lotus had handily left two unused holes up there that I just made slightly larger.
ps. Thought you might spot the string, which is a draw-string for the alarm wires to behind the dash pod. There’s a hole back there that they’re fed through but is was a devil of a job to run them in so I left another draw there just in case.
non-contact thermometer - maybe run a sweepstake for the hottest brakes and tyres - not sure enough people will be bringing girlfriends to include them as a category
small sidecutters (and stainless steel mirror - so I don’t have to be upsidedown)
