Something wicked this way comes...
John will correct me on the bits I’ve got anything wrong, but the electrical system is a work of art and VERY trick.
The Motec PDM (power distribution module) removes the need for any fuses or relays throughout the entire car - you tell it what needs how much power and when and what to do and it takes care of everything!
Because you can set it to take commands from any button or combination of buttons, it vastly reduces the number of switches required. IE If you wanted the start-up procedure to be ‘a quick dab of the horn, followed by a long dab of both light switch and screen washer, followed by push of start button’, that’s what can be set. And if you want ‘ignition on plus push of the starter’ to result in hazards, horn and fire extinguisher firing up, that can also be arranged! Or if you want a starter button to become the horn button when the engine is running, no problem.
A ‘real life’ example of how that would be useful is say a racer comes in for a driver change, you can configure the PDM/ECU to say ‘the moment the air jacks are released select 1st gear and give it 4,000rpm for three seconds’.
ECU, PDM, dash and on-board cam all chat to each other so whatever data the ECU and PDM is receiving (vehicle speed, brake pressure, steering angle, throttle position, revs, boost, temps, pressures, g-force, wheel slip etc. etc) can all be displayed on the dash and/or on video play-backs.
That data can also be read in data logs.
Very nice in-car adjustable brake setup.
So essentially the whole car loom is new? Even lights via the PDM?
You using their trick new CAN switch panel?
Look forward to seeing it at a London lotus meet (ace cafe??).
Complete new loom yes. The one in the car was 12 years old and had a few interesting amendments through its life.
By the time it had the bits and pieces added, in the places we wanted, it was more expensive to modify than start from scratch. Plus the new one is 2/3rds the weight, has a dedicated engine loom plug and has Raychem wire throughout, so more flexible, deals with heat better, etc.
Haven’t got the switch panel that they do, as couldn’t find one that looks good, is the right size and had the correct switches required. Settled for some new light switches and two column stalks from an early Astra, that had cruise control on one stalk - 3 extra buttons - and the multi function display control on the other - 2 extra buttons. This will allow us to change maps, turn on launch control and generally control all sorts of stuff!!
Crikey, I’m happy if mine just starts in the normal way. Nice colour by the way!
A more ‘real life’ example would be to rig up GPS to limit the speed on the A55 :smiley: Or rig up an SMS interface so John can set the boost from the pitlane :smiley:
[quote=Renton]Very nice in-car adjustable brake setup.
Bespoke or Pilbeam or other?
[quote=stevegreen]
Bespoke or Pilbeam or other? [/quote]
Will be JSR’s own version, I have put these on both my Exiges … really good set up
Ey up Andy, has the boat come home yet?
Perfick timing :sunglasses: … boat landed last week and today it was released out of customs so now SSC have to get it passed and stuff … I just have to find a car park that it can get it into !!
Fantastic, Andy :sunglasses: You’re going to cause a right old stir driving the black beastie around Sydney. Any chance of some pics with iconic locations eg bridge, opera house in the background?
+1 on the photos - an upmarket versions of Birds custard just to prove it’s there ! :smiley:
Can you get a photo with the Elephant’s Douche?
Rob, Oh yes - gotta do those for sure, I will get Jude to boss everyone out of the way to get the best shots :wink:
[quote=stevegreen]+1 on the photos - an upmarket versions of Birds custard just to prove it’s there ! :smiley:
Can you get a photo with the Elephant’s Douche? [/quote]
Just for you Steve I will try and find custard, but go to Kings Cross, are you mad ? I could get shot :wink:
I remember getting properly drunk in Kings Cross in Sydney, when I was out there for a trade show. ahhhhhhh those were the days. haha
You mean the days when you actually worked Sean? A long and distant memory I would imagine!
Engine
Audi AGU base 06A 20 valve turbo engine producing 542bhp/485lb/ft torque
75mm DBW throttle body
SEM large port inlet manifold
fully ported/polished large port head, one piece stainless/inconel valves
JSR-spec CAT cams
vernier cam pulleys
uprated valve springs
titanium caps and retainers, solid valve lifter kit
Acid dipped cylinder block, machined to suit all new hardware which include:
Long stroke forged steel crank, giving 2067cc
ARP main and head stud kit
Forged Scat rods
Forged 83mm JE pistons for 9:1 compression ratio
Fully balanced individual components, then as a complete rotating assembly
JSR spec exhaust manifold with external Tial wastegate
JSR spec Garrett turbo, with HDA billet wheel and Tial V band exhaust housing
Full 3in exhaust system, with twin re-packable 6 inch rear silencers and single tailpipe
JSR engine breather with oil separator and sump return, external vapour discharge
JSR spec 4 point engine mount assemblies
Engine Cooling
JSR spec Proalloy main radiator
Electric water pump to enable after-shut-down cooling
JSR spec Proalloy chargecooler radiator, with 5 core chargecooler, 110 litre pump and additional 6 litre tank
Twin front mounted oil coolers, with air feed from front clamshell
Aramid cloth reinforced braided -10 high pressure lines
Fuel System
JSR spec 50 litre aluminium fuel tank with fully baffled internals and integrated central collector
Twin external Bosch 044 fuel pumps
Fuel lab high flow external filter and rising rate pressure regulator with sensor
All Aramid cloth reinforced braided fuel feed and returns lines
Transmission
Close ratio VW 02M 6 speed gearbox with Quaife ATB differential
JSR Spec 6 speed gear linkage
JSR spec twin plate clutch with lightweight single mass flywheel
JSR clutch hose kit including quick release AN connector to slave cylinder
Suspension
JSR spec 2-way adjustable 46mm Ohlins dampers with custom valving and extended rear droop
JSR rose joint kit
JSR T45 front adjustable anti roll bar in S2 mounting hardware
JSR hybrid S1/S2 aluminium uprights, using integrated Lotus bearing/drive flange/speed sensor
Adjustable steering arms and double shear rear toe link kit
Body
Motorsport Elise body panels with widened front and rear wheel arches and Kevlar reinforcements in all wheel areas
Slit rear clamshell and cut back front wheel arches to allow airflow release from wheels
Extended roof scoop
Front air intakes opened to give airflow to oil coolers
Blade splitter running to chassis mounts, covering maximum available floor pan area in wheel wells
Extended rear diffuser into wheel area, including adjustable rod outer mounts, and support for rear lower body sections
Bespoke aluminium rear bulkhead with aerospace heat reflective foil
JSR rear wing pylons with single element carbon fibre wing and FIA dimension end plates
Front wheel wells modified to allow full lock with 17/18 inch wheels.
Carbon door mirrors
Interior & Electronics
Tillet FIA spec carbon fibre seats with fixed runners and 6 point harnesses
FIA T45 6 point roll cage
Bespoke complete vehicle motorsport wiring loom to account for:
Motec M400 ECU with drive by wire (DBW), traction control, anti lag, boost control and launch control enabled
Motec PDM (power distribution module) to delete all relays and fuses
Bosch DBW pedal sensor mounted to chassis with direct actuation from pedal
AIM dash and data logger with all engine sensors via CAN and additional monitoring sensors, linked to Smarty Cam video
Fully customised dash panel and switchgear, multi function stalks to control map, launch and traction control
Lightweight dry cell motorsport battery
Plumbed-in Fev fire extinguisher system
Brakes
6 pot AP front calipers with two-piece 330mm discs
4 pot AP rear calipers with two-piece 315mm discs
JSR spec bias pedal box, including triple master cylinder, remote adjustor, catch tank and brake and clutch pressure sensors. Fully braided lines throughout
Wheels and Tyres
7x17 front and 9x18 rear Team Dynamics wheels, with 205 front tyres and 255 rear tyres
ARP wheel studs and fitting hardware
As taken from www.jsr550.com
Stuff of Legend.
Well done JSR :sunglasses: x 1000
[quote=Renton][
As taken from www.jsr550.com [/quote]
WOW :sunglasses:
Great website to showcase an awesome piece of engineering. Well done lads, can;t wait to see it…
On a different level … stunning, great job JSR …
