I want to get a new snap off steering wheel fitted in the new year and quite like the look of this one…
I noticed it doesn’t have the hole for the horn but does have two other buttons.
Does this matter?
Also what boss kit should I order with it?
Does this matter?
I have that wheel, the two buttons are for the horn or rocket launchers…
This is the hub I use from Works Bell. http://passwordjdm.com/Works-Bell-C332.aspx
Oil squirters!
It’s relatively easy to get the horn to work off either or even both buttons. I have a Sparco wheel and use the fitting kit from Eliseparts that has the two brass studs/connectors that take the circuit from the wheel to the horn.
