What is the proper way to check the oil level on an SC Honda converted car ? Every car I have owned has had a slightly different procedure (run engine, let cool then check or dont run engine, check when cold, etc, etc, etc). Whats the recommended way on the honda ? Does an oil cooler complicate things or not ?
Cheers chaps.
AndyD
2 June 2009 08:45
2
Im sure there may be several answers, mine would be check it cold as thats when all oil would be returned to the sump from the head.
Checking it hot I would wait 10 mins to allow it to drain back or risk overfilling.
The cooler would be filled when you first fill it and wont make a difference unless you have a big hole in it !
Awesome, thanks. Thats the same advice I got from another source.
Thanks.
Remember that for converted cars, the dipstick can be found in the drivers seat
lol
Are you here all week ;O)
DaveP
4 June 2009 19:48
7
And for non-converted cars, the dipstick will be somewhere along your last journey, along with your coolant
Damon
5 June 2009 09:33
8
[quote=DaveP]
along with your coolant [/quote]
Cough!!! Pot…Kettle
[quote=Damon][quote=DaveP]
Cough!!! Pot…Kettle [/quote]
Just what I was thinking Damon
DaveP
6 June 2009 08:00
10
Hahah…I knew someone would pick up on that - I’ll have you know it was simply a user error and nothing to do with the fine engine that sits behind me.
