Well here is a short report, and I mean short, cos it would be impossible to tell you all everything that happened…
First thing was a pretty long lecture on vehicle dynamics, with the beginning of the subject of weight transfer - you would not believe how the weight moves around in response to brake, accelerator, steering wheel, and degree and rate of movement of each of those controls, bearing in mind that the controls produce interacting effects…
Then an equally interesting discussion on heel and toe technique, with the blunt assertion that if we did not bother to do this we might as well go home, cos we would never be competitive…
(If the brake bias is set correctly all wheels will be at their grip limit under full braking, so if you add engine braking to the rears with a mismatched gearchange the rears lock up and you are in trouble…)
We then went off on track to do heel and toe for several hours… and I got the hang of it !!!
Then we discussed racing lines, and the need to get the fastest exit speed from the corners leading onto the straights, and compromising corners that lead to those corners, and approaches to hairpins, etc etc.
Then we went on track to put it into practice, with an instructor at every corner, taking notes…
Every track session was followed by an individual debrief from every instructor on every corner - and they don’t take prisoners, I can tell you
Sometimes we were in single seaters, and we had a steadily rising rev limit to keep things happening at a speed we could learn from…
Other times we were in elises with instructors beside us, giving constant feedback…
WE also did regular car control sessions on slalom courses, getting expert at sliding at varying speeds until it all happened instinctively…
Cars for the slaloms included single seaters, caterhams and an audi A4 on a hydraulic cradle (enough to make you lose your lunch!!)
The control sessions worked so well that by the time we were using full revs I often lost the rear during hard cornering, but just caught it without being bothered in the slightest - something I could not have done before!!! (and of course kicking myself for losing exit speed whilst going sideways!!)
I passed my ARDS OK, but four people didn’t !!!
Separate twin race report to follow
