I have got a 04 NA s2 exige, its just coming up to 20,000 miles and going to give it a service (or go to garage) aint decided yet.
anyway, i want to put the best i can into it, and was wondering what you use?
What grade does it say in the handbook? If it’s 5-40, you’ll have no probs with any of those mentioned above, but I’d change the oil after 3 or 4 trackdays or 6K road miles (or less if doing trackdays). I’m sure the oil will still be in good nick, but for the sake of �50 I’d rather be safe than sorry!
Just use a good quality brand of the grade specified in the owners handbook. Don’t forget if you have the twin coolers it takes over 7 litres to do an oil change. Mind you draining the oil out of the cooler rads will be a pain in the arse. I would just drain the sump and refil, with a new filter of course, so you will probably only need between 4 and 5 litres.
i have looked in the handbook to see what they say< but the reason i posted this up is to see what the majority of most people use! I havent got the twin oil coolers< so straight forward job! cheers!
My 05 Yota with 30k runs happily on Mobil 1 0w-40. According to the manual the oil coolers don’t need emptying/refilling, so I haven’t.
Also according to the manual the service intervals are 9k/annually for engine oil/filter, 27k for airfilter, 54k for transaxle/plugs and 4yrs for coolant. Where did you get the 20k figure from?
I use that silkolene stuff from opie oils. Partly because they always seem to have a special offer on, but mainly 'cos they deliver it to my house so i don’t have to go to halfords.
Even if you’ve only one oil cooler you’ll still have the returns all the way to the front and back, I can’t imagine one little cooler holding that much? I use anything from 4-6l to refill mine depending what mood it’s in.
Well actually it didnt say 20k, it said every 4th service, which would be around 20k…to be honest i think its a waste of time, theres nothing wrong with the coolent in her, i have no cooling issues. Im just going to do the engine oil…
What about gerabox oil then guys? anyone changed theirs? will mine be ok on 20k?
Cheers for the replies guys!
