seat harnesses
Hi can you fit harnesses with the standerd seats in are there points to fix to already there?
regards
norheee
4 point harnesses can be fitted with standard seats, you do however need a harness bar, which requires you to cut out a couple of small sections of plastic from the rear bulkhead so that you can fit it, mounting points for the harness bar already exist on the roll over bar, the other parts of the harness just fit where the original seat belts were attached.
Dave
I got mine from Geary at Elise Parts - fitted reasonably easily - had to cut some of the plastic away though - but worth it for the security and feel you get on track…
Thats great, there are some pics of the fitting of the bar at elise parts too so thats all ok then thanks
northeee.
