Guys, after some Info. The bolts that hold our seats Into the S2 Exige. I see that they are colour marked, what is this for, and do they have a certain position at the rear, with that I mean, one that must go at the outside, inside, If you get my drift.
Also, when your fixing the seats back In, do you put loctite on the bolts? When I removed them, all the bolts were rather slack, so I was thinking, either they do come loose frequent, or they just were not torqued up correctly. I suppose It is a worry with them, that they could actually be stripped, and then your in the Poo. Cos lets face It, so much you do to the Exige involves having to remove the seats.
I was thinking to apply some Loctite to them, but just wish to check before I do, encase this is a big No No.
Also rather than starting another thread. Has anyone wired in another 12 V extension for running Sat Nav’s and Cam’s?
Paul
