Hi guysi I’m looking for the bolt that holds the seatbelt on to the seat on a Exige S3.
Thanks Paul
Thanks Paul
Item #5 or #8?
Lotus have no stock or anything on backorder
Ah I see. Have you got one bolt that you could remove and measure? The seatbelt bolts are 7/16 thread, but it’s critical that you get the correct grade too. This is normally marked on the head as a series of lines or a number (such as 8.8 or 10.9).
You also need to measure the bolt length, the shoulder length and diameter, and then make sure you get the right type of head. There are specialist seatbelt bolt suppliers online that might be able to help.
