Anyone used it on an Exige & put it down the vac pipe ?
Nobody then lol , I didn’t risk the vac tube method and just added it to the fuel to clean the injectors , at the same time I cleaned the throttle body with this when the car was running : Linky
The result is the car now runs great, like new , the stalling pulling up to a stop has gone and the idle is much better , I have driven around most of the day and not one stall , I had replaced the MAF & Lambda sensors before and that only worked short term and I would say most of that was down to the ECU reset , as I did both at the same time today I’m not sure which one has sorted it but I suspect it was cleaning the throttle body , fingers crossed this seems to have got it
I’ve had it at Heston’s . Does that count?
Ha ha , I’m not sure it’s the same stuff , did his smell like it was petrol based ?
[video:youtube]<LINK_TEXT text=“- YouTube … ata_player”>Older intro video to Sea Foam Motor Treatment and Sea Foam Spray - YouTube</LINK_TEXT>[/video]
