Reading the Schroth blurb it says clearly that HANS should not be used with ASM belts.
I am a HANS fan so this means I need a completely new set of belts. NOT ASm.
Anybody know anything about this?
If you wear them as a 4 point (as they are most probably set up already) then i think you can use Hans with them.
Its only when you use an additional crotch strap (5/6 point) that they advise that they are not suitable for hans.
If you read the yellow label on the shoulder strap of your harness in thecar it may say on there words to that effect.
Yep it does hence my querie…I do like 6 point so it looks like a new harness then.
