S2 Geo settings
Can anyone post the geo settings for the S2 please?
Took delivery of my car on Saturday and want to get it checked before my 1st track day with the car in May.
I dont know the settings but it is essential you get it done.
It will transform the car’s feel and handling. I kick myself for waiting 8 months before doing mine at Sinclaires. By all accounts the factory settings are understeery, I had it changed to give a very pointy but grippy front end, whjich is what I like.
My Sport 135R was way out ex-factory, it felt like a totally different car when it had been back to Sport and Performance and re-set!
Just received from Dave Massey…
Suspension
Type
Independent. Upper and lower wishbone; co-axial coil spring/telescopic
damper unit; anti-roll bar
Steering axis inclination 12 � nominal
Geometry specification - Standard Elise:
Mid-laden ride height (reference height for geometry check)
  • front 130mm below front end of chassis siderail
  • rear 130mm below rear end of chassis siderail
Castor - optimum + 3.8� - tolerance range + 3.5� to +
4.1�;
max. side/side 0.35�
Camber - optimum - 0.1� - tolerance range + 0.1� to - 0.3�
max. side/side 0.2�
Alignment - optimum Zero - tolerance range 0.5 mm toe
out, to 0.7mm toe-in overall
Geometry specification - Sport Elise, Exige:
    4.1�;
max. side/side 0.35� Camber - optimum - 0.3�
  • tolerance range - 0.1� to - 0.5�
    max. side/side 0.2�
    out, to 0.5 mm toe-in overall
Rear Suspension
Type Independent. Upper and lower wishbone; co-axial coil spring/damper.
    Camber - optimum - 1.8� - tolerance range - 1.6� to -
    2.0�
max.side/side 0.2�
Alignment - optimum 1.2 mm
toe-in each side - tolerance range 1.2 to 1.8mm
toe-in each side
max.side/side 0.3 mm
    2.0�
max.side/side 0.2�
Alignment - optimum 1.5 mm toe-in each side
  • tolerance range 1.2 to 1.8mm toe-in each side max.side/side 0.3 mm
