Is it easy to adjust the driver side door as it is rubbing the front wing or is a dealer job. I had a look but being crap at anything that requires a tool bag decided to leave it.
Anyone done this.
Anyone done this.
Are you sure its the door & not the clam that needs adjusting?
IIRC a few peeps had issues with adjustment of the clam
Tim.
Ah right…not sure, but the gap between the back clam and the door does seem to be a litle big. Due a service next month so will wait until then.
I had exactly the same problem with mine when i got it.
From memory i adjusted the door position on the 3 bolts that the hinge is attached to the door.
I seem to remeber it only taking a couple of mins to sort, not a hard task.
Phil G
Cheers Phil…will have a go.
I had problems with the door dropping, had warrenty replacement of hinge…only took a yr or two.
I does seem to be a problem. I had the same issue on my S1 Exige.
My S1 was great. When I got it, both doors rubbed, the engine cover rubbed, and the front access panel rubbed Lotus build quality for you
My S2 is perfect
Nowt wrong with an interference fit - it aids aero don’t you know
…and the S1 needs all the help it can get in terms of drag
