Any electronics experts on board? Abs light on/no speedo, after much head scratching and poking and prodding the ABS pump seems to be the issue, sent the ecu off to ecutesting.co.uk but they haven’t been able to pinpoint an issue, helllpppp!
Tell me you’ve checked the fuse ?
Is TC disabled too ?
All on the same fuse
Yep, all fuses checked, getting all correct inputs/outputs on the ABS ECU, might be a case of parts swapping now.
