Checking for source of my "wont pull below 2000 rpm"problem I found that the Coil pack has been rubbing on one of the water hoses that run very close to it…Its only a matter of time before it rubs through and Pssssssssssssssssss.
Where do I buy a replacement hose please?
Thanks Pesky. 'king years since I’ve seen that one. Nice way to start the day.
i just had the steel water pipe welded up because one of the small spring clip tabs had worn a small hole in the pipe right on the shoulder of the socketed part where it slips over the spigot and O ring of the stat housing.
Its very likely it was like this from factory assembly.
I urge all S1 K owners to check the four clips are not lined up like mine were!!!
Simon
Sorry the images are huge - could not be arsed to resize them.
[image]http://i16.photobucket.com/albums/b4/captaincunto/CIMG1108.jpg[/image]
[image]http://i16.photobucket.com/albums/b4/captaincunto/CIMG1111.jpg[/image]
[image]http://i16.photobucket.com/albums/b4/captaincunto/CIMG1113.jpg[/image]
