S1 Perspex Engine Cover
Sounds like this insta profile wants reporting as a scam!
100% a scam, I’ve reported them.
Well done mate :+1:
Phil you got a better off than me it was £600 yesterday :rofl:, he gave me a postcode so i said i could meet him as i was down the road. weird he went quiet after that. thanks for posting it on the other pages etc, hopefully no one has fallen for it
Hello, I would also be interested in this. Is there a price and any lead time on getting some made up? Thanks
@Greenelise86 is there an update ref producing the Perspex engine covers?
I also read somewhere that you were looking at producing the wheel arch liners for the S1, any progress?
Cheers.
speaking to a second supplier for the persepx the first one struggled to get the return on the edge.
Arch liners I’ve made the first set in GRP, I’ve got someone to do some test time with them to check that they fit fine and hold up to the abuse too, will probably be going out for testing next month. it would have been on my car but other commitments have slowed progress on the build
It all sounds very positive :+1:
I’m happy to test them :+1:t3:
I ve been offered a new one and new wheel liners. I think it was £1200 for cover and £700 for liners. I passed on it but can ask.
luckily i bought a brand new perspex so ill risk getting that moulded
Liners are still available new however in typical lotus fashion theres more of one side available than the other.
Ill message you later Phil on testing them out for me, hopefully i can get a few sets done and get them tested, ill also lay up a small piece the same as the liner and fix it to the arch of my daily drive. im quite often running round mid wales with work so itll give it a good test too.
The other bits im looking to get remade are roof seals and front grills, i cant think of anything else off the top of my head that isnt readily available
Roof seals would be very handy :ok_hand:
You’d have to use polycarbonate, pretty sure Perspex hasn’t got the UV stability…
itll be made of the same material as the factory one.
Hello, did this go anywhere?
in short no, tried multiple manufacturers including the original one and they struggled to reproduce the lip. I made a full grp version which mesh or plexiglass can be bonded into which can replicate the look of the original. Ill still try more companies as i still have a new oem one to mould off
Hi All,
I have for sale an S1 Perspex engine cover.
The black paint was peeling off and so I started to strip it, luck me someone offered me a replacement but that had crazing on the top surface, I sent it to the polishers and it came up great so I used that instead.
So now many years later of keeping this just in case I’ve decided to let it go.
The lighter colour is masking tape I was using so as not to slip into the clear part.
You could either carry on striping up to the masking tape or easier would be to paint it on top, should have thought of that back then! The clear bit is in good condition.
Not sure on price so if anyone wants to suggest a price or make me an offer then I’m open to that or if not there’s always fleabay!
