As MarkA says, suspension should be looked at as a complete package.
Lotus went stiffer on the ARB when going stiffer on the springs/dampers when fitted to the Exige. Got the numbers somewhere, but been driving all day! Will try to dig them out.
Logic says if you’re going stiffer again on springs/dampers, then a complimentary ARB will be of benefit. How much, is open to the same debate as spring rates, Nitrons/Gaz/Ohlins.
There is so much more than just spring rates and anti roll bar stiffness.
A few examples are
Tyre type, temp, pressure, tread depth
Geo settings inc ride heights etc etc etc
Track surface/type/temp
Driver input/driving style
Vehicle weight
and im sure mant many more
What works for one person may not be the ultimate for another.
