Complete set of KELSport wishbones taken off my racer in 2004 when I met Mr Pilbeam…
These have spherical bearings for ALL joints, inner and outer.
This sale contains everything. All wishbones, joints, sleeves, mounting plinths, steering arms, toe links, double shear links, spacers.
Please note that the rear lower outer joint with these is not a taper fitment it is a straight through 1/2" bolt to fit the motorsport rear upright.- I can get a tapered spigot off Pilbeam for a little extra on the sale price to allow use with standard uprights.
Also the toe links mount in the ‘proper place’ on the wishbone (not some apologetic little add-on bracket on the subframe).
I painted these black whan I got the car so it was easier to see any marks or damage as the bright metal showed through. That said they are totally undamaged and corrosion free.
No idea what these are worth as they came with the car so again, offers welcome.
I well and truly reserve the right to give preferential treatment to fellow racers with these.
Feel free to correct me if any of that is wrong Steven but my understanding is that KELSport modified standard wishbones to take rose joints and supplied all the neccesary bits to make them fit.
They are not Pilbeam items, These are Standard S1 wishbones professionally modified by Kelsport KELSport clicky
They can be fitted to ali hubs - the fronts alreads do, but the rears would need bearing mounts like these :- eliseparts clicky
If you use the spigot from the steering arms they will fit to any steering arms designed to accept a taper joint.
The inner bearings on these wishbones are press fitted between two inserts, these can be pressed out to enable you to replace them with the Nitron bearings.
