I know this subject has been done to death, but just wondered what suspension set-up you chaps are currently running? Had a quick search through the archive, but couldn’t find anything relevant. Anyway, I’ve got standard S2 Ohlins and rear mounting brackets, and I’m hopefully going to do more than my fair share of track stuff this year, and that’s it. Looking for tried and tested recommended settings?
State: Laden (Driver +20L)
Approx Ride Height F 112 R 122
Castor 3.8� (actually running a bit outside this now, but haven’t adjusted it)
Front Camber -1.1 degrees
Rear Camber -2.5 degrees
Front Tracking: Parallel to 0.2mm toe out overall
Rear Tracking: 2mm toe in each side
Seems to work well for me. I was running the front ARB at one click off full soft initially but found the rear too loose on corner exit so I’ve stiffened it up 2 notches and it sticks like sh1t to a blanket now Oh, and I run 048s.
It’s far from a definitive setup, but thus far it suits me pretty well and it’s a good base to start from
Aye-up Pesky, hope you’re well mate. Cheers for the replies chaps. My spec is nearer S2, than S1 now I think. Out of interest, does anyone have the spec that specialist like Plan use?
