Genuine 2001 Exige, in Titanium.
Forged K20 engine, uprated gearbox, full suspension refresh. Circa 550bhp high boost, 400bhp low boost. Motorsports seats.
Subject to extensive performance modifications by Lotus specialist Maidstone Sport Cars.
The chassis is on 58k miles, engine is around 2k miles since full rebuild. Specs on all the components below, to the best of my recollection, all paperwork available:
Performance is eye watering, and a fortune has been spent on it over the years. Selling due to lack of use/family commitments. Currently SORN, but will be sold with fresh MoT and service.
I’m happy to answer any questions, but please follow the link/ call Maidstone Sports Cars
SPECS:
Honda K20A2
Built bottom end; 9.6:1 87mm pistons, forged Rods, uprated bearings, Block guard, new timing chain, tensioner, other “while you are in there” bits e.g. head gasket, ARP head studs.
Garrett GTX3071 spec turbo
45mm Turbosmart external wastegate
4 port Hondata boost controller
70mm throttle body
Dual PWR barrel charge coolers
Pro Alloy triple pass rad
Pro Alloy charge cooler rad
CWA200 Chargecooler pump
Zircotec coated turbo manifold and 1.06 ar exhaust housing
Custom 3” exhaust with dual silencers to meet track noise limits
ID1050x injectors
Spitfire Engineering updated in take fuel pump (700bhp rated)
Pro Alloy 48l fuel tank
550bhp, 400 ft lbs at 1.6bar, more tuning potential with turbo/injector upgrades
Hondata Kpro V4 ECU
Oil/water cooler
Rebuild gearbox
Exeedy uprated clutch
Lightweight flywheel
New OEM syncros
GearX forged helical 1-4th gearset
MSC gear cable setup
OEM 5th and 6th
OEM FD 4.764:1
Kazz 1.5way LSD
New Nitron 40mm Club Sport coilovers inc helper springs
Adjustable ARB
Rose jointed bushes
Spitfire toe links
Full suspension refresh, fresh powder coating, all wishbones and bushes etc
AP 4pot front calipers
Bigger discs all-round, 308/304mm
Original Motorsports seats
Momo steering wheel
Additional dahs digital gauges, Oil pressure & Temp, IAT & Boost pressure
Harnesses plus drivers side seat belt
