This is a pretty rare set up is a plug and play Emerald for an S1 Exige with a VHPD.
- Emerald K3 - perfect working order - three maps loaded - MOT map, track map and experiment map.
- Map switch on a long cable.
- Adaptor loom that plugs directly into the Exige Harness and the K3 at the other end, no cutting needed. It includes everything that can be connected including the canister purge and aircon (not that it works).
- Remote switch to hold on the electric water pump fitted to some S1 Exiges (to cool the head)
- Relay and single connection so the fuel cut off still works - just take a power feed of the switched ignition circuit
- Programming cable.
- USB to programming cable adaptor -as few PCs have a RS232 these days
- CD - better to load the latest off the Emerald site.
The base maps gave my VHPD 188 bhp on the dyno, it is a standard engine with verniers.
Posting it on here before SELOC.
Any questions, just ask.
I would think £650 is a fair price for the whole lot which is less than I paid for all whole lot.
