Hi Guys,
My clear out continues and I have the following.
1 pair of Original Lotus Motorsport carbon door cars for an S1 Exige / Elise - £150
These are unused and straight out of the mould, so will need a little trimming etc.
2 x carbon centre console rear section, that runs from the rear bulkhead to the gear lever surround - £150 each
These are unused and straight out of the mould, so will need a little trimming etc. They also don’t have a handbrake cut out, so you would need to add that is you run a conventional handbrake lever
1 x carbon speedo backing. This is not the binnacle, but the piece the clocks would fix too and the internal roof of the binnacle. - £75
This is unused and straight out of the mould, so will need a little trimming etc.
