RUSTY steel under S1 Aluminium engine bay tray...
Thanks a lot mate!
I would like to change it with something better if possible.
Joseph
This is what need > http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=NIMG2C >
This looks really great! I will be replacing the rusty looking one now! By the way, it is an optical illusion… the rivets are fine but good spot!
Cheers,
Pete. [color:“blue”] [/color]
Pesky, you do know thats the same stuff as used on an s2! You mellowing in your twilight years?
Must be
Now, where’s me tin opener?
Whilst deep cleaning in the ‘engine room’, I noted, having pulled out the sound baffled foam from on top of the aluminium storage tray area behind the air box, that this appears to be attached to a thin mild steel plate running across the full width of the boot!
Horrors of, but it is RUSTY!
Any history in any threads of this… as this needs to be replaced!!! (YUK!)
Cheers,
Pete. [color:“purple”] [/color]
what did you use to clean the boot?
Try this …Replacing the exhaust heatshield with Nimbus - TechWiki
Might give you some guides
Try this …> Replacing the exhaust heatshield with Nimbus - TechWiki >
Nimbus does seem to be the favourite product for this.
